Also the spring caps will influence spring preload, ducati alone has three different heights.
So pack height, spring stiffness, spring preload, spider spring spec and ramp angle will affect slipping, so its a jungle unless you have complete kit fitted that has already been tried out.
Ive never seen a pack with less than 36mm, so you should probably stay above that.
I just did a monster 1100 with DP slipper and oem discs along with the caps that gives the lowest preload, no clue what bike it was for, customer didnt know either, I had to choose from 37.0 or 39.0, so this guy was new at tracking and had no clue what to expect so I picked 37 to have it slip a good bit. Went for a testride and it slipped right away in first gear even, and thats where preference come into play, I would think thats too much, but some like to see their money invested delivers, so he was happy with that.
The stack height in this case doesnt tell you anything meaningful unless you know all the other factors I mentioned.
I like the least amount slipping while still being able to dump the clutch and not upset the chassie to a point of losing control, with my setup stack height is 39mm.
General tip would be, if you like two stroke engine braking go 36.5 if you just like to shut the pulses from the engine out and use the clutch manually 38.5-39mm.
OEM packs typically comes at around 40mm (compressed in a vice), so one disc out usually gets you in the ballpark for a slipper.
