95 SSCR. When re-installing my forks after a rebuild one of the threaded bosses on the RH handlebar clamp snapped off at the weld. I've considered a direct replacement (I see some used on ebay) or a weld job. However now I'm a bit paranoid about the condition of the other side as well. Has anyone fitted Apex clip ons on an SS? It looks like the 50mm, 7/8" bar, 3" riser should bolt right on. And would be an upgrade in adjustability. Any other aftermarket replacements to consider?
