FIXED: Steering lock adhustment bolt removal
599 views 5 replies 2 participants last post by  BIG O
#1 · (Edited)
UPDATE: easy remedy, removed the oem nut and replaced with an acorn nut that was bulbous enough to reach/touch the steering stops...maintains good turn radius and prevents damper from touching the tank.
I know I'm new to the SC1000 world but very not new to motorcycles but for the friggin' life of me I can't seem to remove the steering stop adjustment bolts. I added an Ohlins steering damper and need to prevent the damper from touching the tank but there isn't enough adjustment in the bolts. I was gonna find a larger nut possibly to make up some of the distance ot remove the oem bolt snd swap in a longer bolt.
I back it out (from the front of the bike under the headlight with the bolt coming out towards the front) and it just hard stops. I mean hard stops about halfway out. In either direction. I assume (maybe incorrectly) that it isn't supposed to back out going in the direction of the tank as it looks like there's a bit of a head where the allen goes into. (If this all makes sense)
#2 ·
So you are trying to increase the bolt length which in turn will decrease your “lock to lock” distance? It’ll also increase your turning radius?
If so, I had a similar issue and ended up glueing a washer on the stop.
Be advised, even the thinnest of washers will really increase your turning radius.
#3 ·
Exactly. Just want to leave a comfortable...I dunno....5-ish millimeters between the damper snd the tank. The tank is lined so I don't expect too much expansion
Good idea on maybe JB Welding a bumpstop extension on
#4 ·
Make sure you do a test fit with whatever you use for a spacer before you JB weld it on.
You might be surprised how little it takes to increase the turning radius.
I ended up having to go with a thinner washer because it practically took an airport parking lot to do a u turn 🤣
