61 - 80 of 142 Posts
Discussion starter · #68 ·
That was one of the stock .bins that Dutch posted. Like I said, I accidentally copied over my original file.
That most recent .bin didn't work either.
Yes i am using IAW reader/writer.
It says programming successful each time, with no changes to show for it. Immobi light is still on.
Dutch, is it not weird that we can only find one place on the internet other than this thread that says the immobi is in that location?
I mean, like I said in my drunken rant, this is starting to seem actually impossible on this bike...
You can not load a 59m into a 5am or the opposite . Load the wrong one and you would most probably brick your ECU.
The immo light will be on if i dont remember wrong.
The question is your immo and XDF. I have only used ducatidiag to flash the 59m ECU and there you just disable it at the screen. I have used XDF and guzzidiag for my 5am ECUs.
What does guzzi/IAWdiag diagnostic software say when you connect. If i dont remember wrong you look at the status it will tell you if you can start or not and why not.
Sent from my SM-G935F using Tapatalk
