speedbleeder.com
2.8K views 12 replies 11 participants last post by  Stick
#1 ·
Has anyone purchased and installed any bleeders? I purchased the ones listed on their web site specifically for the multi but they are not the correct size. The site lists the sizes for an 11 but I have a 12. Is there any difference?
I've emailed the site and I'm waiting for a response.
#5 ·
Me too. I ordered a full set including clutch right off their website recommendation. They worked perfectly! Excellent product. Maybe something was just miss marked?
#6 ·
Another rave endorsement: less than 10 minute install for all 3 calipers and the clutch slave cylinder, followed by fastest/easiest/neatest fluid change and bleed I've ever done: highly recommend!
Mike
HB CA
#8 ·
As I will bleed the rear regularly, I couldn't agree more, best $7 USD spent on the rear brake yet... Did the fronts too, all bought from the web site as they suggested.
Note the small ones for fronts are a different size hex, it's 1/4 as they say on their site they can't get metric stock in the small size reliably.
Cheers John
#13 ·
Just want to make ALL aware that there is a "No Bleed" method for getting rid of the air up near the Master Cyl. This definitely works for coffin-style and remote reservoir style masters. Not sure about Radial masters.
I wrote it, and it's in the H.O.W. section.
#10 ·
The initial problems with the size was posted over two years ago, maybe they fixed their site.
I just installed SpeedBleeders on my Goldwing, it needed 7 of them. The Goldwing has a sequence of bleeding the front and rear brakes as they are linked.
The Speed Bleeders made doing a complete fluid flush and bleed very easy.
I also recommend their fluid catch bag, about $5. It fit perfectly on the bleed nipple and I could place the bag where I could see it so I could see when the new fluid had worked its way through the system flushing out the old.
I got mine here
Speed Bleeder liquid recovery bag and hose combo.
#11 ·
On a side note, if for any reason you plan on changing your brake lines, hang onto the OEM caliper nipple.
It is almost impossible to force the air out of the line and draw fluid down using a Speed Bleeder nipple.
