This is on a '06 Sport 1000. I'm going to try to deal with the stock suspension until I get a better suspension, but in the meantime, I need some help getting the rear Sachs shock adjusted. The owner's manual is pretty much useless.
My main problem is with the stock front forks bottoming out under hard braking (I weigh @ 230# with all my gear on). Took my bike in for service last week and noted that the rear shock is leaking slightly, which will be replaced under warranty. My mechanic said my stock front forks were performing about as well as expected for a Sport 1000, which is not that great as far as I can tell. He said that if the rear wasn't damping enough it might help cause the front end to bottom out.
I note that the spring preload is adjusted below the bottom 1/3 of the threads on the shock body. I assume this is too much preload.
Any tips on adjusting the rear shock for my weight, etc.?
Thanks!
Thanks!
