Hello all :smile2:
I have a question for all you fast guys.
I have seen a lot of you guys changing your stock bolts to titanium Bolts/Screws.
You have inspired me to to the same - OK, I will start with the Brake Disc Screws.
I really thought that it would be an easy job - and it probably is - but I am in a personal conflict if I should follow the tecnical instruction and apply Loctite 243 Medium-strength Threadlocker or something else.
I am affraid that if I use Loctite 243 Medium-strength Threadlocker that I will not be able to remove the Titanium Brake Disc Screws in the future because of corrosion and seizing.
On the other hand I am affraid that if I do not use Loctite 243 medium-strength threadlocker BUT an Anti-seize Compund that the brake disc screws will come loose over time during riding....
What have you done???
Have some of you tried to remove Titanium Brake Disc Screws that have been sitting for some years WITH Loctite Threadlocker. Did the opreration go well OR did you end up stripping the Titanium Screw Heads??
If you only have used Anti-Seize for the Titanium Brake Disc Screws have you the been in a situation where you have discovered that some of the Brake Disc Screws have come loose?
Sorry to bother you guys but I really need some help here....
Ciaooooo
Moller
Ciaooooo
Moller
