Haha yeah, it's a little hard to sort through at times... I find that using Google Chrome's translate feature made everything MUCH easier to find!
There's actually one post in the International Section, which is a guide... I'll repost it here so you can find it easily! Remember, if you want to use it to flash your ECU, you'll need to purchase the writer program for 100 euro for the first ECU, and then 50 for any subsequent ECU.
"I have just recently joined this forum and have managed to figure out with help what exactly I need and how to use it !!!
I though I would make a 'basic' guide in english for those not sure what they need and how to use it.
If any 'expert' users want to add to this then please do so with tips, advice etc.
Firstly I bought,
This
http://www.ebay.co.uk/itm/2608335744...84.m1439.l2649
and This,
Fiat 3pin Alfa Lancia To OBD 2 Diagnostic Adapter Cable | eBay
Other cables are available but these ones work and the prices are good, took about 3/4 days to arrive.
Then I downloaded this,
Ducatidiag24
from
http://jpl250rs.perso.sfr.fr/download.php
The only other thing you need is the com driver which is different for the various operating systems but is available on the website, somewhere !
Here is the one I used for xp, it work with vista /sevenn too
http://www.ftdichip.com/Drivers/CDM/CDM20814_Setup.exe
or latest
http://www.ftdichip.com/Drivers/CDM/CDM20824_Setup.exe
Test your cable 1st
Download
http://jpl250rs.perso.sfr.fr/test/cable_testc.exe
connect cable to battery ,but not to bike loom.
if test2 is ok , then you can follow
GETTING STARTED
1 Connect the blue cable to your laptop or pc via usb
2 Connect the 'fiat' cable to the blue cable and plug into the bikes diagnostic plug and connect the + and - cables to battery
3 GO TO DEVICE MANAGER AND CHECK WHAT PORT YOU ARE USING -- VERY IMPORTANT !! ( This port can change )
3'' Download
Use same com port as found in device manager
Connect cable to battery ,but not to bike loom.
If test2 is ok , then close application and follow the rest of the process
4 Open 'Ducatidiag' and change the port number to whatever port you are using.
5 Click on connect and turn on ignition - You should have your ecu information displayed.
6 Copy your ecu details in full from the screen and post them in the 'Licence required' section or PM them.
7 When you get your license file link sent, download the file and copy into the 'Ducatidiag' directory.
8 When you next connect you will notice that the 'Service' and 'TPS' buttons are active, you can now reset them.
9 I recommend that you make a 'Dump' file of your standard map and save it to allow you to reload it if ever needed.
The TPS needs to be reset on a CLOSED throttle
You can also check fan operation, fuel pump, injectors, Co2 etc etc
IF YOU WANT TO FLASH YOUR ECU.
If you would like to change your map from standard to the DP slip on or full system map, or any other map that is available you need to purchase the writer program. This can be done by contacting jpl250rs
Once you have obtained the writer and whatever maps you require you will be given a writer licence which will only work on the ecu that you have registered, you can though change the maps on this ecu as many times as you like.
Further licences can be obtained for other ecu's by following the same proceedure at a reduced cost.
When you open the writer you connect in the same way as with Ducatidiag and you search for whatever map you require. Once you click on this map the writer will automatically start to load the map. A bar will be seen on the screen that displays the progress. The ignition needs to be turned on.
MAKE SURE YOU KEEP CONNECTED AND DO NOT DISCONNECT UNTIL YOU ARE INSTRUCTED TO TURN OFF IGNITION.
You may need to reset your dash to whatever region you are located in, this can be done by holding down the left button while turning on the ignition, go to the relevant section choose your country and hold the switch down to save it, turn off ignition.
I 'think' that is about it for the basics, good luck !"
