Clutch slave cylinder o-ring change
3K views 1 reply 2 participants last post by  mopgcw
#1 ·
From what I can gather, it appears that my clutch slave cylinder is leaking as there is fluid buildup around the cylinder itself and drops on the garage floor after a ride. It isn't an all the time type of thing, but have noticed it every once in awhile cleaning up.
When changing the o-rings on the slave cylinder, is this a task that will just require removing the cylinder, putting in the new o-rings, and that's it or will I need to bleed the clutch system?
Thanks for any help
