I was hoping to try a lighter fork oil in my "new to me" Diavel Carbon. I currently have preload fully out (no preload) and compression and rebound damping is also fully out (completely open CCW). It has the standard fork oil (Shell Advanced Fork 7.5W-spec's - 4.9 cSt at 100C) in it and was only ridden for only 1 year summer before the previous owner placed it in thier playroom.
I wanted to try two things to get the damping in the adjustable range and slightly reduce preload:
1-swap fork oil for a thinner oil, like Redline Extrelight fully synthetic 2.5 wt- 4.0 cSt @ 100C. Should I go lower? Say shell 5W - 3.8 cSt at 100C or Maxima 5w - 3.51 cSt @ 100C.
2- Lower the fork oil height to reduce the air spring effect say by at least a 3 cm (~1.2").
I wanted to try this before considering a softer pair of springs.
Any thoughts would be appreciated.
All the best
Mike
All the best
Mike
