Guys,
What are you aiming for when checking valve clearances? Also, do you pull the shim if its inside a hundredth of the bottom# or top#?
Example:
Closure clearance on a 2015 Multi is .05 - .10
Are you shooting for around .07 -.08?
Do you pull the shim when its inside a hundredth from out of spec? Example= .06 or .09 pull it?
Thanks
Example:
Thanks
