Hello,
Once again sharing my experience with this 2001 Ducati Monster 900s ie. This times is because I went to ride the bike and it started up, all good on (cold) low speed / low rpm (0 - 25 mph / 1k - 3k) and after a couple of miles on med speed/ med rpm (40 mph - 55 mph / 4k - 5k rpm) the bike started dying on stops. Once you go and pull the clutch to throw 1st gear she dies. Then if it does start up it gets rough idle until it dies or very unpredictable low rpm sputtering, suddenly accelerating with very little throttle opening.
I'm thinking she has an open or stuck fuel injector where after running at med to high rpms and coming back down there's unburned fuel in the chamber and it just dies because it can't create the combustion. Fuel is 93 octane, more resistant to pre-ignition.
It has new fuel pump and filter, new premium gas.
Anybody else had this happen before? Any ideas?
