OEM vs. Ca Cycleworks ExactFit Timing Belt Tension Difference
4.3K views 12 replies 7 participants last post by  belter
Honestly, are the cams really going to know the difference between 110 and 99 hz? What I mean is, is 11 hz really going to be the difference between the belt slipping a tooth and causing catastrophic engine damage?
I’m not a Ducati specialist but common sense says no. Once the belt has been on for a while, it will probably settle at around 95-100 hz or possibly a bit less.
Reactions: chris_f
Too tight is no good either. There is a thread somewhere regarding the specs for the DS1000 engine belts. It is (or was) significantly greater than that of the 900 engine. Turns out it was an misprint in the factory service manual. Apparently many sets of tensioner rollers were sacrificed before this was discovered.
