Have any of you guys (or gals) ever had a stuck fuel injector? I was cruising down the freeway Tuesday when my ST4s started running on 1 cylinder. So far I have determined that I have sprark & that the cam timing is still correct. The fact that I have spark would seem to mean that the ECU is still working & that the coil is good. No pinched fuel lines so it isn't that. It starts right up & runs on 1 cylinder. Just wondered if a stuck injector ever happens. I'm going to swap injectors from 1 cylinder to the other & see what I get. It looks like taking the airbox out is going to be fun. NOT!!!
Gregg
Gregg
