The link I have in my bookmarks is "https://www.perthstreetbikes.com/forum/showthread.php?t=129737". The links to the pictures, which are handy but not essential, are all broken.
The Ducati SS manual has exploded view of both CR and SP front forks. It's free online, PM me if you can't find it.
It's possible to do the oil and spring changes without removing the forks, but it's so easy to take them out and work on a bench, I wouldn't bother. I had my SP forks apart many times, it's pretty obvious once you get them apart.
No idea how the Marzocchi CR forks work, but for the Showas fitted to the SP's:
- Remove the front fender, brake calipers, wheel/axle/speedo drive.
- Remove fork from triple
- Unscrew top cap, dump out oil (hold top tube so it doesn't retract down into stancheon and dump oil on you)
- Let go of top tube, let it retract.
- You need to get a wrench on the nut which is inside the top of the springs... you'll need to somehow compress the spring and slide a wrench on. I used two screwdrivers with the shafts run between the spring coils, handles on opposite sides so I could push the spring down while my lovely assistant fitted the wrench.
- Have aforementioned assistant unscrew and remove the top cap. Watch out, the spring needs to be held compressed or the cap will end up in outer space.
- Once the cap is off there's a couple of things, spacers, end plates, that slide off, then the spring can be lifted out.
If you have Marzocchi forks, they have very limited adjustability and IMHO are not worth putting any money into beyond springs and oil. They're fine for road riding for most people.
If you have Showas, know that they have a defect which causes adjustment of compression damping to affect rebound damping... i.e. those two adjustments should be fully independent and they're not which makes it damn near impossible to set them up perfectly. Look at my previous posts, I ended up installing GSXR internals in my SS forks along with RT springs and would HIGHLY recommend this mod if you want maximum performance out of your forks... the Suzuki internals are far and away better than the stock stuff and they work properly as far as damping adjustments go.
