241 - 260 of 467 Posts
Is there enough length so you can run the line behind the fork? It will sit cleaner at the master that way. Also I think you will find the line will may rub and get caught between the fork and the carbon air tube the you have it . Another suggestion. Loosen the carbon air tubes off quiet a bit and remove the mesh from the fairing. This way you can see if the tubes need to be modified at the fairing. As you tighten the tubes you will see them move all over the place. I've had to modify 3 of these tubes for customers so the fit at the fairing is acceptable. On one bike the fairing wouldn't push back far enough to screw it on.
Discussion starter · #244 ·
The lines aren't long enough to fit like that, I tried everything and the pictured position is the only one that works. It does touch the air runner at full lock but it's not a problem. They are zip tied to the lower triple to prevent rubbing when turning.
The air runners fit very well, no adjustments needed. They are made by MS Production :)
Discussion starter · #249 · (Edited)
Front brakes bled, chain riveted and adjusted, fairings mounted with new titanium Dzus fasteners (apart from tail), tail light and vent meshes mounted. Now just in need of a license plate holder, hoping to get it sorted next week.
Although I haven't ridden the bike yet and discovered a small oil leak on the alternator cover I'm still happier than a dog with two dicks!
EDIT: Oh yeah, forgot the official spec wank sheet:
Chassis, brakes, controls:
-unnumbered 999R race frame with removable brace bars in RS-style, no clips for electrical connectors, repainted
-Öhlins FGRT 819 forks with billet bottoms and Ti bolts, blue decals replaced with black ones, 1098 spindle
-Öhlins DU510 rear shock with hi/lo speed compression adjustment and a hydraulic preload adjuster, blue decal replaced with a black one
-NCR billet ride height adjuster with Ti pinch bolts and adjuster section
-Öhlins steering damper with Ti bolts, blue decals replaced with a single black one
-Ducati Performance blue anodized steering damper bracket with Ti bolts
-Speedymoto black billet top triple and clip-on brackets with Ti bolts
-carbon fiber clip-ons with Ti bolts
-Ti rear axle nut
-Gilles Tooling chain adjusters
-Brembo P4 30/34 billet front brake calipers with Ti bolts
-999RS04 front brake hoses
-999F06 Brembo 320x6mm narrowband full-floating rotors with 5mm spacers and Ti bolts
-Discacciati four-piston billet rear brake caliper with Ti bolts
-billet underslung rear caliper bracket
-Discacciati 225mm narrowband rear brake rotor
-HEL Performance carbon look rear brake hose with stainless steel banjo bolts
-ABM Synto black clutch and brake levers
-Oberon black billet master cylinder reservoir covers
-Supersprox Stealth rear sprocket with Ti nuts
-Supersprox front sprocket with Poggipolini Ti nut
-RK GXW 520 gold X ring chain
-Marchesini forged aluminium wheels, repainted and with fresh decals
-Pirelli Diablo Rosso II 120/70 & 180/55
-RCM Racing 999RS replica rearsets with Ti bolts
-999RS carbon heel guards with Ti bolts
-999R Xerox OEM black brake pedal with custom bolt
Engine & electrics:
-Akrapovic 749RS 57mm WSS full titanium/carbon exhaust with Ti mounting bolts
-999F06 carbon oil breather tank with Ti bolts, custom made airbox connection
-Pipercross filters
-MS Production oversized carbon air runners
-Ducati Performance ECU
-Shorai 18Ah LiFePo battery with custom carbon cover plate
-Digital Guard Dawg keyless go, ignition switch removed and blanked with a carbon plate
-garage door RF remote integrated into right hand switch unit with a 12V/3V DC/DC converter
-ExactStart additional starter and ground cables
-wiring harnesses re-wrapped with Tesa 19mm fabric tape, all connectors treated with CRC contact protect
-999F05 four-spring ramp type slipper clutch with Surflex aluminium plates
-Oberon 29mm clutch slave cylinder with Ti bolts, upgraded rod with Ti pin
-HEL Performance carbon look clutch hose
-Samco silicone hose kit
-749RS coolant union with Ti bolt
-Ducati Performance magnesium valve covers
-999RS04 sandcast and vented clutch casing with Ti bolts
-stainless steel case saver with Ti bolts
-most of the external bolts replaced with Ti
Fairings & other stuff:
-Beater Japan 999RS-style aluminium tank (22 litres) with aircraft style keyless cap, repainted
-749R 2004 carbon side fairings and winglets, repainted in OEM-style with 999S texts
-Ducati Performance carbon facelift front fairing, painted in OEM-style
-RS-style tall windshield without parking light, Ti bolts
-999RS carbon tail fairing, custom paint in OEM-style, custom aluminium rear mount
-Ti Dzus fasteners
-Radiantz LED tail light/indicator strip integrated on tail fairing
-999RS carbon seat
-749RS carbon seat/tank mount with Ti bolts
-custom made carbon heat shield for silencer
-Ducati Performance magnesium headlight bucket
-Ducati Performance magnesium mirror stays
-Ducati Performance 1098 carbon front fender with Ti bolts and a new Corse decal
-Ducati Performance short carbon hugger with Ti bolts
-Ducati Performance carbon mirror covers
-Ducati Performance carbon oil cooler fairing with Ti bolts
-Ducati Performance carbon belt covers with Ti bolts
-999RS carbon belt cover for vertical head, with Ti bolts
-999RS carbon clutch cover with Ti bolts
-carbon seat pad cover
-carbon swingarm covers
-carbon rear brake m/c cover with Ti bolts
-more Ti bolts (around 200 in total)
-Motion Pro coolant catch tank
-horn relocated under the headlights
-black mesh on tail and front fairing vents
Probably forgot something!
Power isn't important. Weight would be interesting. I would offer advice for the number plate but can't help here. The few that I have done for similar muffles have all broken because of vibrations. Even the Zard muffler that I drilled and put riv-nuts on cracked the Ti skin. You could always mount it to the swinger like they do with Harley's :)
Well, chasing an ultimate power figure on a dyno may be a fools cause, but power to weight is what makes any sportbike interesting, or REALLY interesting...
And the curious amongst us would like to know what jusutus has got on his hands here, power to weight wise
Discussion starter · #254 ·
Sprocket cover and front axle? Weight and power.:)
Won't be running a sprocket cover this summer, just to show off the factory Ti sprocket nut :D Front spindle is off a 1098S. Still need to get a Ti nut for it.
No idea about the weight. Maybe I can borrow a scale at some point and have a look. And not really interested in the power figures since I ride like a granny anyways 0:)
And to think some folks think the 999 is ugly.....that's just beeyootiful.
Yes, stock they are a lil' visually challenged but to my eyes there are 2 things that corrupt what are still quite fresh looking lines: that ugly little moulded in tank pad (I grit my teeth every time I see one!) and the hideous stock muffler/shroud. I'm not keen on the wings either and run my ol' girl without 'em, but if all Ducati did was clean up the tank and tidy up the arse they would have sold a helluva lot more of them for bugger all investment.
Sorry Jussi, don't mean to distract from your amazing effort. Your previous little snippets have been like looking at individual flowers, each little modification very nice in isolation.....then we finally get to see the full picture, the complete garden with the flowers en masse....and it's pretty spectacular. Not in your face or overly flashy, just very very classy.
Discussion starter · #256 ·
Cheers @seven4niner :x
I agree on the tank pad and stock silencer setup being the ugliest part of the original design. I'm also not a fan of the seam on the plastic side fairings :(
My goal was to upgrade the bike in OEM style and RS-look as much as possible, instead of shoving in all the red anodized Rizoma tat and cat-sized DUCATI PERFORMANCE decals that's available. There are not super many non-Ducati parts on the bike and the ones that aren't made by Ducati still follow the conservative looks, including the reservoir covers, levers, top triple etc. The swingarm decals will be removed soon :)
And if anyone has not noticed I looove carbon >:)
Yesterday I got some material for a license plate holder, it will be made from 1mm stainless steel. Will be visiting the garage tomorrow, hoping to get the holder done and the bike washed/waxed.
Looks good and all the bits just add up to something extra ordinary. Talking about stickers the only one that bothers me even the slightest is the white Verlicchi frame sticker. But since you have this street bike style mixed with RS bits (and without racing livery) the swingarm stickers seem a bit out of place too as you stated yourself.
I like the exhaust and even if it's not "made by Ducati" (which most of the parts really aren't anyway) it's still Akrapovic and Ruben Xaus raced similar looking model in the World Superbikes with his Sterilgarda Ducati 999F05 in 2006 if my memory serves me right. It doesn't slot in the race fairing like a Termignoni Corse system does, but still looks good.
Discussion starter · #258 · (Edited)
Thanks @Jyrki :)
The Verlicchi decals are trying to mimic the bike where everything started, the F03:
But as with the swingarm decals, they are a bit too big and like you said without a race livery they are a bit out of place... Might ditch them too.
