What color/graphics on a bastard 998/1098?
  • SPS Red
    Votes: 27 51%
  • Tricolore
    Votes: 15 28%
  • Why the eff should I care?
    Votes: 11 21%
998/1098
40K views 72 replies 35 participants last post by  ejayerik
#1 ·
Anyone ever wonder what a 998 might look like if it had a 1098 engine in it? WONDER NO MORE!!!
#2 ·
:eek::think::abduct:
#3 ·
VERY NICE Daniel!!!!!!!!!!!!!!!!!!!
You are my new hero. ;)
I just bought a 748/996 frame I plan to modify to fit a teste motor and add an 848 into it. That of course when I get the other projects done. :D
#4 · (Edited)
Did you take more pics during the build? Did you have to modify engine mounts or cut / weld the frame to get it to fit? Those intakes look HUGE! Road test yet to get a feel for stability? What exhaust did you cram in there?
I'm predicting this to be a quite popular thread. Nice work Daniel!
#8 ·
Pics were taken just the other day. It's still a work in progress. My 916 engine died and this seemed to be the logical progression. The exhaust is the Termignoni 70mm full system. It fits (barely) and will take a little adjusting. I was going to use my 916 frame but I traded it for a 998 frame. Basically made a whole new bike. If the 748/996 is 2000 or '01 I believe the bolt holes will be 12mm (as the 998 and all new SBK's). The 998 frame required NO modification to fit the 1098 engine. If you use the 748/996 frame I'm sure you will have issues fitting the throttle bodies. See pic.
The front velocity stack is pretty close to the frame, but I'm working on fabbing a custom airbox for it. Also, 1098's hold the injectors in the airbox lid so I'll have to cook up something else (ala 748r or 998)
#12 ·
1098 airbox bottom half and 748R top half.
it's coming together...
#14 ·
1098 radiator, oil cooler, ecu, wiring, and dash. Basically I'm transplanting the whole 1098 into a 998 frame. There's a guy in the U.K. who is doing a 1098/998 build with a 998 ecu/harness and a power commander, but I'm not sure how his progress is coming.
Daniel
#19 ·
Wow that is a great swap... I am glad to see that basic hot rodding techniques is alive and well in the Ducati community. We did a swap like this in my Mustang, 04 Cobra engine into 96 GT and the cool factor let alone the performance of a modern engine into an older platform is really neat. Can't wait to see the finished product. Great job....
#23 ·
It might be a flexi flyer, but then again assuming the 998 f02 had similar HP to a stock 1098 then the 998 frame should be able to accomodate the power.
The weak link would probably end up being the rear shock and swingarm (although I think that might be a corse swingarm he's got on there...)
#24 ·
916 donor wheels, suspension and brakes. The subframe is 998 bip (I had the alu p8 mono subframe on the 955, but I want 2 seats)
The 70mm Termignoni system fits without too much tweaking. You run into fitment issues with the rear sets and brake cylinder, but nothing insurmountable.
