OK, I did have some install issues, the aluminum handguard bar did not fit the handlebars well, the bar is designed to fit the "short" front clamp for dirt bikes, but since we have the masters on both levers we have to run the optional longer front bar clamps, there lies the problem, the angle of the handguard bar is all wrong for a clean install, putting to much stress on the bar end mount with a ugly angle, so what did I do? I found a tree in my front yard put the handguard bar in the crotch of a thick tree branch and
bent it! just like a real *******!
I "opened" it up so the longer front clamp will now fit. I knew bending it wasn't going to be a problem because the handguard bar is made from semi soft "malleable aluminum" and now the handguard bar fits well on the handlebar, like it should.
I also had to remove & reinstall my Fabbri windshield to install the front bar clamps, and just like (typhon) said, I had to put tape under the switchgear to help it tighten on the handlebar, the LED lights went in fine with NO filing, and are only half as bright as stock as they are small, and because of my Slick50 rear LEDs my turn signals now blink too fast. But in the end, after the 2 1/2 Hr pain in the butt ordeal, it turned out nice & I like it. Aloha Alex
PS: a side benefit of the bar conversion is that because of being able to move my controls around, (no locating tits) I can get my conventional mirrors out farther and I can see behind me better than ever before!
