I know there are a lot of posts around the forum on that topic but still it is not clear to me and I would appreciate if someone can give me a clear answer...
I got a 2008 Hyper with the Zard Penta Slip-ons... everything else is stock.
So,
1). Should I change to a DP ECU or the stock one should be fine?
2). Will I get any "Check engine" lights on if I change to a DP ECU (if I understood it correctly from other posts than the DP ECU is set up for Termis so it may not work with the Zard slip-ons properly...)?
3). Can the DP ECU be changed or remapped for the Zards without getting any other stuff such as PC111 and so on?
Thanks in advance for any comments/suggestions.
So,
