over at the show in Birmingham i was talking to a guy who had a set of zard end cans foe £640.00. I was wondering if these pipes fit straight on without any other modifications so I thought that you guys could help. Would i need a different ecu
straight fit, lousy instructions...ecu not required, but desirable.
2nded.
For a Zard slip-on no ECU. Hell, even a full system isn't so bad with just a Fatduc O2 manipulator, works ok.
My bike was significantly worse than stock with Zard Penta - not much power, a lot of popping and no whelies (only in first gear) ... much better with the fat duc... so I guess the DP ECU will be even better...
Im running the ZARD penta full system with a DP ECU thats for the 2 into 1 system. Freaking love it. Pulls much harder then stock and is smooth as silk.
