Earlier this year I had a very gunked up clutch slave cylinder (translates...leaking) . In the process of installing a new Yoyodyne slave I upgrade to a 916 master (original master shot) and put in a new braided line. Went to test drive and while I can see the outside pressure plate go in and out, the clutch in not engaging and disengaging right. Not sure what the problem is. The Yoyodyne should be plug and play. Has anybody heard of any quirks with the Yoyodyne slaves? The clutch stack is relatively new and was fine when the bike went down for the winter.
Edit; I noticed the pressure plate WAS NOT spinning with the clutch lever pulled and the clutch dis-engaged.
Suggestions?
Jeff
Suggestions?
Jeff
