I recently purchased an integrated rear tail light from Yoyodyne. This is an LED type electronic rear light with integrated turn signals. The turn signals need to be hard wired into the harness with resistors. The supplied resistors are ceramic type, 20watt 5ohm. These things are pure junk. They arrived with shoddy, broken wires and cut shrink wrap. I’m awaiting a reply from Yoyodyne but nothing yet.
My question is, can I swap out these ceramic style resistors for a more compact and robust style resistor or does the LED tail lit require this ceramic type of resistor? I would rather hard wire in a better, higher quality type resistor.
Thanks,
Don
Thanks,
Don
