Everyone,
I need help in a major way! I was out riding on my 1995 916 at night and during my journey home I experienced probably the scariest thing I have ever experienced, the loss of headlights.
Here is the information I have to share if it helps.
-The headlights come back on when I jiggle the large connection on the right side which connect the front harness to the main.
-After turning the bike off with the headlights / tach in the non-working situation the fuel pump still turns on when the key is on and the kill switch is turned to the on position.
-The tail lights still work.
-I clean and grease the connector regularly.
-Lastly, I thought the problem was in the front harness so I replaced it with a used harness and I still have the same problem.
Other important information. I did replace my battery a few years back and the jackwagon who installed it didn't put the caps on all the way so I have acid damage. The damage has been present much longer than the electrical issue.
Thanks for taking a second to look at my post. Any advice would be very much appreciated.
David
I just had the same problem with my 95 916. After an hour of riding, lost the instrument panel and lights while stopped at a light. \I went to the nearest Canadian tire and picked up a pocket tester to see if the RR was dead. Battery was good and getting a full charge. I decided to ride home. 10 minutes later, everything came back on.
I replaced my RR last year with the same brand I've had running for the last 6 years. Battery was also replaced. Both are in good working condition.
All my connectors seem to be tight.
and more importantly, your personal experienceMindfully using our emotions as data about our inner state and knowing when it’s better to de-escalate by taking a time out are great tools. Appreciate you reading and sharing your story, since I can certainly relate and I th ink others can too
