1 - 7 of 7 Posts
Hey everyone,
Bike in question:
1995 900SS/SP
Question about horizontal opening shims being .02mm too loose / gap too large
Every other opener and closer on the bike is now within spec, after a few swaps.
My process:
  • Pull the belts
  • Remove openers on both inlet and exhaust
  • Check closers first
  • Check openers with both inlet and exhaust installed; check the side opposite the side that is engaged / pushing down / rocking
I have a shim kit, but the next shim up won't allow a .10mm (.06 will fit) and the next size down takes me out to .16mm
Haynes reminds me that my acceptable range is .10 – .12mm
So I'm calling it a .14ish, which is .02 too loose.
I put around 3k a year on her commuting; city and highway mileage, no tracking.
Waiting for new belts and gaskets to arrive, BTW.
Anyone see any issues?
Just Visiting Your Planet
You can lap shims down with 400 grit and a little oil. I use a thick piece of glass underneath so it's perfectly flat.
Yes, 400 grit black wet and dry paper and wd40 for me, turn the shim often and about 45 secs removes a thou.
Make sure you wash the shim with brakeclean and dry before re measuring, carborundum in the engine is not recommended by the manufacturer....
To extend the discussion a bit…
What are the repercussions — if any — of running for another interval (6,000 miles) with openers that are .02mm too small?
Retired Pipe Polisher C2H6O+
According to LT Snyder’s book Ducati’s specs are 0.05 - 0.12mm on intakes and 0.05 - 0.15 on exhaust.
You can lap down the next size up ship to get it exact. But honestly I’d go with the .02 undersized shim and call it a day. Opening valves tend to get tighten up over time
i wouldn't go under 0.10mm. ime the openers only get tighter when the valves are moving in, and you'll see corresponding loose closers. i find they both open up, closers as the collets settle/wear and openers just a little.
you can rub them down easily.
1 - 7 of 7 Posts
