1 - 9 of 9 Posts
are the cf heatshields on the termi exhaust designed to have vent cutouts? anyone tried this and put like meshwire in it's place?
any of the racebikes do this?
that's exactly what i'm thinking, it looks like it was designed to be cut out like that. Anyone know a good way to do this and where can i get the meshwire?
a dremel seems to messy, i want it to fallow the lines already on the heatshield perfectly.
Carbon Fiber cuts and smooths very easily, just drill a hole and cut the carbon with a fine tooth saw blade, then finish it off with a file. Be careful not to breathe the dust, it sticks to your lungs like glue. After you're done, if there's some scratches, all you have to do is top it off with some clear coat. As far as mesh, office supply stores have the best material, they use it on waste paper baskets, desk organizers and such, really cheap, comes in colors, Lowe's has the black silicone perfect for the applications, I use these for anything, even for a screen on the belly pan of my Brutale
1 - 9 of 9 Posts
