1 - 3 of 3 Posts
Hey Everyone,
My 999R blew a hole in one of the fuel lines within the airbox while on the dyno and started a fire. Thankfully I only lost the air-filters and internal fuel lines to the fire. Ducati does not sell these lines, but rather an entire injector kit including the velocity stacks, injectors, etc for $1800.00. I am only need the fuel lines from part# 135.2.009.1A. Of course, no warranty for a 2005 with only 3000 miles.....
See attached picture of the parts. Again I am only looking for the hard fuel lines within the air box that run to the injectors.
Any ideas? Any availability?
Thank you all for your time and assistance!
just cut off the old plastic crap and use some fuel line with compression clips....
Dealership liabilities if the oem plastic lines aren't used= $$. Anyways, dealership found a used set of the plastic lines for $200.00. I'll eat the $ and replace all the lines with some nice high-pressure rubber lines and O-clamps at home once dealership replaces with oem lines. Apparently a known recall on these plastic lines EXCEPT for the R models according to Ducati...... They crack and split just like mine did EXCEPT on the R models, but obviously applicable here too.
Thank you
1 - 3 of 3 Posts
