1 - 9 of 9 Posts
Looking for the followings
- 45mm to 50mm collector and 50mm exhausts
-track oriented rearsets (no gp shift)
- marchesini wheels
- the plastic protector that goes over the front “V” fairings that keeps both lower side fairings together (does it exist?
Mayor of Simpleton
I've got a couple sets of magnesium Marchesinis available.
- marchesini wheels
just posted new never installed full akrapovic exhaust, 207-233-2024
That looks nice but I am not sure I will fit my current stock 916 setup? I mean the header pipes - will this setup bolt on? What is the OD? Thank you
Mayor of Simpleton
Could you please send me prices? I assume no cracks and they are safe to be used on track?
Yes, they're all in good shape. No elongation of the rear mounting pin holes either.
- marchesini wheels
Do you still need an exhaust?
-Dave
No such thing. The V panel bolts on to the brake on the head, the side panels are 'independent' and attach underneath using the Dzus fasteners. Hope this helps.
1 - 9 of 9 Posts
