looking for a vertical head with good rockers cams not needed to replace my damaged one
Mine is a 99. St4 is the offset head right?
yep, probably wouldn't work for you then but not 100% sure
St 4s head is going to use different valve lengths because of it's shape. Can't remember but I think the intakes are 10mm shorter. If you get a complete head, it may not matter and bolt on ok.
