1 - 3 of 3 Posts
Incredible results.
We installed the baffles to Chunks bike 5hrs ago and run up a new twin cyl feul map.
To say we were pleased with the result is an understatement and encouraging for the guys that 'must' run baffles in their Termi kitted bikes.
A few weeks ago I posted a graph of my SC1000S in bog standard "off the floor" trim vs my bike with a full Termi kit with the baffles (db killers) installed.
If you go back thru my posts you will see these graphs. Both bikes (disapointingly) produced much the same hp.
The following is the same graph but with the addition of Chunks GT with the WaspPUKs1 kit and the Termi baffles installed.
That is:
Bog standard = RunFile 010
Termi with baffles = RunFile 002
WaspPUKs1 kit with Termis with baffles = RunFile 016
Howzat for a jump in hp??????
Greg
Love your work, and i also appreciate the information that you pass on. I noticed that the run conditions where 20% lower and the humidity 15% higher (approx) on the Termi with DP killers run. Would that amount of change make a differance to the end results.
cheers
Nev
1 - 3 of 3 Posts
