And just how do you know that, you bad taste person?migz123 said:Either one (passat or gti) will do the job.
CKvBP said:Your looking at this all wrong you shouldent be asking "would you hull your bike with this" but "would you drive this with 3 supermodels or a fat chick in the back seat" if the answer is yes then you can hull your bike. Afterall, its a lot more aerodynamic than the fat chick.
P.S. I just spent my nonpoliticaly correct chovanist pig allotment for the year! whoot!
I've owned 3 GTI's, a Golf, a Scirocco, and currently have a Passat Wagon ... At nearly every moment of the last 20 years, I've had a VW ... I missed the '84 Golf GTi by one year though. They'll all tow anything, unless its too heavyMV_999R said:And just how do you know that, you bad taste person?
Have you seen the 84 Golf Gti?
bemikevel![]()
your car, no offense , is not so high in the evolutionary chain either...and is now problematic hence why you are considering replacing it!!!....I am just giving you the benefit of the usual problems and what to look for and why....the timing belts and tensioners should be replaced as a set at about every 60K....I think 60K is pretty much the industry wide standard for timing belt intervals....some folks have a tendancy to want to push the limits on things....that philosophy can cost you big time with the newer multi valve interference motors!.....that is parts of the possible negative for the gains in power and performance and cleanlyness of emissions through technology!!!grendels_arm said:Wow even my car doesn't need all that stuff that often. Timing belt every 60K and check tension but that's it.
My Honda Civic isn't rated and is not recommended to tow anything. It's still running strong at 206,000+ miles, though (still on the original clutch, too).bebopdontstop said:Do yourself a favor. BUY A HONDA!!
