1 - 9 of 9 Posts
I started with the pit bull rear stand but returned it and got the MOTOMFG stand, it works great and is built solid, the wheel kit makes it a breeze to move the hyper around the garage. It is less money then buying a front and rear stand from pit bull and so much nicer then those regular stands.
Oh yeah and as a member of this forum you get 10% off if you buy from him.
cheaper than $70 shipped?
No the MOTOMFG stand is not cheaper then $70, I meant it is cheaper then the pit bull or t-rex stuff. Personally I would not trust stands that cheap. The pit bull stands are made very well and there was still some slight movement of the bike when I worked on it, so I would not trust any of those bargain type stands(like they say you get what you pay for).
When you look at the cost of a front & rear stand from pit bull or t-rex the MOTOMFG stand is less $$ and a lot more flexible for working/storing the bike. That is what I meant. If you want to check it out let me know and stop by one day
Here is a link to the stand;
MotoMfg paddock stand Ducati
it is $340 +
1st Gen Hypermotard Hooligan
I know the rear will work, however, you will need to install spools.
it is $340 +
I know where my next paycheck is going. And I already have a front + 2 rear stands one for single sided and one when I have my slider spool combo on. Damn it
on second thought maybe not. Anyone know why you can't run this with aftermarket rearsets?
It has to do with the upper mount for the MOTOMFG stand, you replace the one bolt on the stock rearsets(big silver thing) with the upper mount for the stand that comes with it, easy to install. the hardest part was the adjustment to get the bike to sit level it takes some trial to get it just right but it is easy to do
looking to get some cheap stands for the hypermotard and I have no sliders installed. Think this will work?
MOTORCYCLE BIKE SWINGARM PADDLE FORK FRONT REAR DUAL LIFT STANDS COMBO | eBay
I have a pitbull in the rear and one of those for the front. Your gonna nned to mod it slightly. The forks on the hyper are too wide so you just gotta drill an extra hole where the locking pin is. Very easy thing to do but to be honest if i could do it from the beginning I would of got the moto mfg stand.Ya your gonna need to install spools in the rear.
1 - 9 of 9 Posts
