1 - 3 of 3 Posts
I have a buddy with a 1999 748. Anyways he had an accident and I have a 1098 base that now has ohlins 803's on it.
Will the OEM showa forks fit his 748? and rear shock if anyone knows
Mayor of Simpleton
No on the forks and highly unlikely on the shock.
The rotor offset is 15mm on the 1098 vs 10mm on the 748.
No speedo pick-up provisons
Axle spacing slightly different
Different axle required
Brake mounts are radial
fork diameters are the same
fender mount is the same
It can be done. You will need axle, calipers, discs...
1 - 3 of 3 Posts
