1 - 6 of 6 Posts
I have a 95 900sp. It has a pro-italia slave cylinder on it. Its leaking. The seal is junked. Not sure if pro-italia still supports this product, they're closed today. Need to have this fixed before the weekend. Found a new style stock slave cyl on ebay ending today, just wondering if it would fit my older bike. I've read that the new style were good for 2001-on, but it looks like it uses the same bolt pattern etc. Anyone have experience with this? Thanks
the slave cylinders haven't changed, as far as i know,
it is the clutch rod through the shaft which is somewhat
shorter on the older models, and some slaves
come with an extra extension piece for the older
bikes - again, as far as i know.
so you should either have got the extension piece
beneath the aftermarket slave on your bike already,
or make sure it is delivered with the new slave.
:think:
my engine is from 2003, i have no extra piece
installed, bolt pattern etc. is the same as with
my old '95 slave.
cheers.
:think:
Hi!
Just did the same mod on my '95 SS - the original was leaking too. The new style cylinder needs a longer actuating rod, but you can keep the original if you put a 8mm (whatever that is in inches) ballbearing into the new cylinder before slipping it on ti the acuating rod. I used a dollop of grease to keep the ball in place while fitting the cylinder.
Hope this helps!
Esben
1 - 6 of 6 Posts
