2007 1098
check engine light is on.
now getting "Error coil 11.2" and "10.2". these codes state that each coil is grounding out somewhere.... (?) which i find very, very unlikely. I had a perfectly running bike before I did the tune up (no codes).
did a full tune up on bike, I did change the spark plugs. spark plug boots look good (no big massive white corrosion).
I have read that i might need to replace the injector/coil/fuel pump relays (located on the right, rear side of the battery behind all the wires an hoses). I have swapped their position, with no noticable change in how the bikes runs, nor any codes that magically cleared themselves.
I cant ride the bike for another few days due to weather, but it seems to idle and rev just fine.
I did forget to plug in the immobilizer antenna unit thing upon reassembly, causing code 37.1; this code seems to have gone away since the immobilizer has been plugged in.
codes only show up if you press the "up" button the left handlbar stock, otherwise you can start the bike and run/idle it and never have any idea there is a code, aside from the CEL light which remains on.
So are these just old, stored codes? will fixing the (non aparent) problem cause them to go away and the CEL light to go out? How can you manually clear the CEL light to see if the codes come back?
Thanks in advance, glad to be part of Team Ducati !
