It looks to me like the bolt spacing is similar and the length of the shift rod is close enough
but you will loose a lot of leg room and pull your feet 2 inches up and aft about 2 inches. It will be VERY different!
( I'm measuring my stock SF and Satos on my 1098)
The brake side may be a bit tougher because the brake lever on the SF will be too short and too low, you'll have to use one from a 1098.
Also the exhaust heat shield will have to be removed but you won't have to worry about that with your new exhaust.
No guaranty but from my quick measurements they MAY fit but I don't think I'd like the change personally.
