No, I am really wondering, why do people continue to buy these things?
Ok, I just need to rant a bit.
I bought a 2014 Hyper SP (slightly older, not the first generation, but super clean and low miles, so it should be safe and pretty well sorted, right??). I paid a fairly high price (to me) because it was a bike that I always wanted to try and I decided to go in agnostically and just see how it turned out. Had 4k miles on it when I bought it so, coming from Japanese sport bikes all my life I thought, it should be good to go for a long time. So naive of me...
First thing I learned is that the belts, while not being over their miles are over age so, off to a Ducati expert to change the belts, plugs, fuel filter ($800). I wouldn't want the motor to grenade because I didn't follow Dicati's recommendations on regular maintenance.
While at the shop, one of the O2 sensors decides to give up the ghost. I have 2 choices, replace the sensor ($300+ for the official Ducati part) or have the ECU reprogrammed to eliminate the sensors all together (also $300+). I decided on the latter since there are 2 of them and the second one is probably not far behind. But, more on the programming later.
Then, I am noticing a pulsing in the front brake. Off to do some research on the interwebs, and Lo and behold, this is a known issue with the 2013 and 2014 bikes. Supposed warped rotors very early in life. I am still not 100% sure that is the complete issue but, another $600 for new rotors. I have ridden bikes for 35+ years and I don't recall ever having to replace a front rotor, even due to wear, and I check the thickness to ensure that they are within specs.
Then there is this issue with the throttle when riding at a constant throttle position, IT DOESN'T! Up, down, up down. You can't hold a constant rpm with this bike to save your life no matter how hard you try. More research. Oh, the early ride by wire throttle may have been too light, spring wise, and they went through 5 different iterations (with us as their test subjects) to maybe make it better. I still haven't got the latest version to check because well... other issues to deal with.
Now back to fueling; I had the bike tuned by Rexxer because it seemed to be a reputable tune company and I hoped that it would fix the $hitty fueling along with removing the need for the O2 sensors. The bike has an SC project slip-on so I was sure that tuning was going to help. Well... It still idles like $hit, and burbles down every time you let off the throttle and just for good measure it will stall on you every once in a while just for $hits and giggles. It is great when WOT, but who rides the bike all the time at full tilt on the street.
Next, the bike turns over like a 1930 ford being hand cranked and sometimes fails to start on the first, or even second, try. Oh, this is because Ducati, in their infinite wisdom, decided to use undersized wires to the starter and use improper metal for the connections. Another $170 to buy a kit to fix Ducati's $hitty engineering.
Finally the clutch, Oh the clutch. It grabs at different positions every time you let it out and you need to treat it like an egg shell lest you will be buckin, grabbing and generally looking like an a$$ any time you try to launch at anything more than a granny's pace. Oh, just put a 939 clutch pack in it to address another example of crap engineering and no proper testing (another $200+)
Then, to top it all off, you can't even reset the service light when you change the oil without buying a scan tool for $500+. Are you freaking kidding me?
The bike is interesting, and fun to ride, although all the issues are making me resent it more and more every day. It is unwieldy, unpredictable and seems to have more issues than middle-aged rock star. They all look really good but they are in the "danger zone" of the crazy hot matrix.
Who buys these things? Me I guess. I will do my best to turn this into a motorcycle that I can live with but it definitely will be the last one I ever buy.
BTW: I am a Director of Quality at an engineering company so I know what goes into testing complex new products and what it takes to make sure it is ready for sale to the market. As long as we keep buying these products, Ducati is correct in their thinking that "it is what the market will bear".
I also can't speak for other models that Ducati produces but, I would bet good money that they are not any better, quality wise.
Go ahead and tell me that "you just don't understand" or "maybe you just can't afford a Ducati" and that is fine, maybe those points are true but I will not be buying another Ducati, and ultimately, that is how I really cast my vote, with my wallet. I am just glad I didn't spend full retail price on this poor excuse for a road going motorcycle.
Rant over
Jeff
Rant over
Jeff
