Of course I forgot to mention a couple of things. (Mr Magoo)
If you’ve gotten the calipers super hot, the pistons and the body of the caliper can warp to the point they won’t release until they cool down. Even though you fix the vent problem the pistons may intermittently stick with hard use on a track day. Same goes for the master cylinder. I’ve seen brakes get so hot it melts the wheel bearing grease. The internal liner of the brake hose can also separate from the heat and intermittently restrict the flow of brake fluid. The brake line may need to be replaced in extreme cases.
if you have ABS, the pump may suffer damage. It’s hard to say for sure. If ABS brakes feel like they still have air in them, one trick is to activate the pump while back bleeding them. An air bubble gets in the ABS pump and normal bleeding won’t remove it. Rapid pulsating the pump with the system test tool will shake the air bubble loose.
