Hey..
I'm changing over to a new windshield. Same OEM as original, but the original mounting threaded rubber grommet on the shield had aged and crumbled when I tried to remove it, so I bought a couple of new ones.. SKU: 85040821A
Thing is.. Now I've assembled it, it doesn't look right. The orientation is the same, but the new grommets are crushed considerably less than the old ones, but it doesn't look like the rubber tubes will torque down enough to crush them up to form a snug fit, so it's just sitting half loose with only the flanged end holding on the windshield.
Is there something about this threaded rubber connector I'm misunderstanding? The thread is at the hex end, so torquing won't crush it to form a bulge.. One of the two original grommets was uncrushable enough to see that they are in fact the same length, originally, but just don't tighten down the same, and I don't want to take it too far for fear of stripped the threads.
2007 Ducati Monster S2R 1000 by AMS Ducati - Issuu
92-93, part number 3
Hrm.
Any input appreciated.
Hrm.
