I bought this ST with these heated grips already installed; however, there is no controller.
Does anyone know which grips they are? I would really like to get them working for some winter riding but have zero experience with heated gear.
Discussion Starter · #2 ·
Even if you dont know which grips they are, advice as to how to get them up and running would be helpful as well.
Thanks
I'm not familiar w/ that connector. Are the heated grips the overlay part, or the rubber grip itself?
In any event, that I would do is ohm out the value of the resistance on those 2 pins.
Most grips are wired in parallel (getting 12V to each grip). A few might need to be wired in series (6V to each grip).
But basically, they're about 10 to 15 watts each, when they're on 100%.
R = V squared / P
So if they're dintended for 12V, it approx. should measure out at 10 or 12 Ohms.
If it measures around there, I would apply 12V to each one and see if they are still working.
If they heat, then you should be able to use any heat controller for them. A cheap one to buy online is on ebay:
https://www.ebay.com/itm/Mini-DC-Mo...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2648
It handles up to 5A. Your grips should be using no more than 2.5A at 100%
Note that you'll probably want to water-proof the circuit board to make it last...
The heated grips are the actual rubber grip, and you can see in the second picture has a little button with what looks to be an l.e.d. I just have covers on them right now, which is the bit you see peeled back.
Thanks for the detailed advice instructions on diagnosing the voltage.
Thanks to Sticks advice, I hooked my meter up to the 2 pins and it ohms out just over 10. I DID ELECTRONICS! haha I then hooked up 12v to the grips individually and they work! Even the little blue leds light up. Each grip has its own button to turn on and off, which I never noticed.
Still searching for a decent controller that will accept these 2 pin connectors. I was told by a buddy they look to be similar to the connectors used for sonar/dept finder systems on boats of similar vintage. Anyone have any idea about what these 2 pin connectors could be?
