okay. so in the small window on the engine it appears to be empty but when i took off lid to the small case, (witch also said use brake fluid?) thats attached to the clutch lever its inbetween the upper and lower marks.
Is there somewhere else i should add the fluid or can i just not see the fluid in the engine window?
and how come the fluid box on the clutch says use brake fluid?
