Took my Side panels off and this hose dropped out when I wasn't looking. Is there a clip for it somewhere? I'm assuming it's a drainage/evap hose? Any pics or links would be great. Thanks!
Jeremy
this hose just curls up out of the way thats the vent for the canister or drain if it fills with fuel,just remove the entire canister and plug the fittings on the intake ports at the throttle bodies and the only vent will be the hose from the tank,unles you have strict inspections for emmisions.
I would like to know where the hose goes as well. I have a 2013 696 and just realized the hose is hanging like the one in the original post. Where do I rout it? Thanks?
Funny, I just ran into this last night. As mentioned, I ended up just jamming mine behind the canister. I found this picture online of how it should look.
-Rob
Temporary greeter
It goes in the garbage along with the rest of the canister. Plug the vacuum lines going to the intakes and run the tank vent to the bottom of the bike.
Enjoy a bit lighter weight and a whole lot of less ugly.
