grendels_arm said:
I bought an FG rear stand last year for the sole purpose that it has a breaker bar. I already own a Pitbull rear stand as well. Anyway one of the metal posts that one of the little wheels sits on is bent at an angle a little. Where do you go to get something like this fixed? I assume a welder. How much do they charge for a small job like this. If it's more than $20 not sure it's worth. Do I let my fingers do the walking to local welder?
Lots of forces you can harness. A simple bottle jack and a large stationary object such as a big SVU, boulder, etc. will work wonders. Try to position under the frame rails, but becareful, lots of "soft" part between the frame. Use blocks of wood to protect parts.
You may want to remove the wheel first so it doesn't get jibbered up.
If you can't bend it with a 3-4k lb vehicle, then try what the others suggest.
As always, you do this at your own risk, be careful, stand clear and go slow. SAFETY FIRST.
Lots of energy released quickly can be life threatening and dangerous.
As an off roader, you have to get creative when doing field repairs. Look around you.
