1 - 3 of 3 Posts
Does someone know the bearing code number for the front wheel bearings on a 2002 750 Monster? This is the wheel with the large diameter axle.
thanks,
-Armen
usually you can find bearings, rollers, etc. at your local bearing supply house for cheap and usually in stock.
just take the old ones in with you.
there's nothing special about the bearings Ducati uses.
right
Uh, right. Hence me asking what the bearing numbers are. I don't want to have a beached bike while I wait for bearings to arrive. If I had the bearing #s, I could order them without knocking them out first.
1 - 3 of 3 Posts
