1 - 7 of 7 Posts
I am replacing my 15 tooth front sprocket with a 14 and would like to know what size socket I need for the sprocket nut? I am at work and would like to pick up one up on the way home. thanks for the help.
Hi mate
Its a 32 i did mine last night, make sure the folks gave you a 102 link chain as they supplied me with a 100 link & my wheel catches the swingarm..twats.
200nm to tighten , swing on that baby..
Thanks Blackie! Had to barrow a torque wrench from the shop next door mind did not go high enough. Guest I will have to buy one as the rear wheel is even higher.
200nm will be ok for the rear, they say 230 but fuck that. The MV was 200 so thats good enough for me.
I had balls like a basset hound as it was , swingin on that fucker
DONT FORGET..35nm for the hub pnch bolts in a 1 to 1 order. DO NOT overdo these or it will fuck the hub up..
Discussion Starter · #7 ·
Just an update. I put on the 14 and liked it much better, but it was not there just yet. So I went back to the 15 and put a 41 on the back. Yes you must change the chain. To me this feels just right for the street.
1 - 7 of 7 Posts
