What kind of clutch plate is this?
500 4
Hi Folks!
I'm just doing a basic service (check, adjust, replace and flush) and while I'm taking the clutch pack apart for a clean I found this clutch plate, which is thinner as Std. and has a flat and convex style "spring" plate (red marks).
Does anyone know the manufacturer of it?
Thanks!
it's the "late style" barnett pack set up. instead of the usual ducati 1.5mm convex steel plate, these have the half steel/half friction thing, and one of the steel rings is convex.
it will also have a 4mm steel at the very back, instead of the 2 x 2mm normal steel plates the ducati pack uses.
nothing at all to do with the silent clutch mod
