1 - 20 of 1318 Posts
Just checking to see what others are doing with their bikes right now.
Since mine is new and I'm going down the customization path (busted up side fairings makes this easier than it would be if they were pristine), I'm doing maintenance, reading up on things I don't know about (plenty) and shopping around on Ebay (Sorry, I'd buy from you guys here but I can't post in the classifieds yet).
Done something interesting?
New parts show up?
It might be inspirational to see what the rest of you are up to.
Average Weird Guy.
Picked up a new left side bar switch. Pic 1
Test fit my Speedhut electronic gauges in my dash. Pic 2
Started masking off my engine cases and covers in preparation for bead blasting. Pic 3
Hey stoshmonster, where did you get the carbon fiber gauge surround?
Thanks! I've been looking for a carbon cover for the triple and the gauge surround.
Wow it's really cheap! :eek: How is the quality?
Removed oil!!
The previous owner must have filled the oil with the bike on it's side stand, as the oil level filled the entire sight glass when put upright. I drained 0.5 - 0.75 quarts out of the engine just to get it to the "max" line.
Fortunately the last oil change was <200 miles ago (I just got the bike last weekly and have put <100 miles on it so far). I'm hoping this is too little mileage in this state for real damage.
On my second ride, I smelled oil burning and noticed a slight oil leak during cold starts. :mad: It was coming off around the belts on the right side and dripping it's way down onto the exhaust. I'm seriously hoping that it was due to too much oil pressure and will subside now that it has the proper volume in the system.
By the way, it made a tremendous performance boost now that the crank doesn't have to dredge through all that extra liquid. For a moment I found myself questioning why this was such a famed engine, but she's livened up quite a bit now.
Next up -- new belts, new (to me) DP high mount exhaust, and a trip to the dyno room.
In the last week;
Checked shims - two openers changed.
Changed fuel filter - hardest part was getting the pump out.
Drained oil and changed filter.
Removed heavy standard flywheel and installed lighter Nichols.
Changed pick-up coils with new Ducati parts. I bought them and hope it fixes the hiccups and steady revs.
Put everything back together and fill with oil - to half a window :)
And it started - once I had added petrol to the empty tank.
Still have put side panels back on and fit new, sitting on the desk here, Woodcraft rear-sets.
Created space for new (to me) arrival tomorrow.
Rode to a friends house, stopped for fuel, the fuel light came on just as I got to town. I noticed the bike surges a bit at part throttle 4500-5500 but runs fine if I wick it a bit. This is not a problem for me, at some point I may check the action of the vacuum slides in that range. I got no flickering oil light, that was the important thing.
Do you use Sea Foam? If not do so. It calls for an oz per gallon. Keeps the carbs happy. I use less in my normal fill ups. Maybe an oz or two per tank. I don't measure that precisely. All the carb gum and sticky issues go away.
Bob
I walked out in the garage, gave the old SS and quick eye f**k and then hopped on the 1098 and went to work. Will probabaly do the same when I get home.
Cleaned/lubed+greased throttle cables and the throttle grip housing. Then reattached and adjusted them. Nice smooth snaps now. Tonight if I have time I'll change the cam belts or install the gas filler.
Question: Does Chris Kelley's cam belt change video apply to my '93 900? I just noticed he has one video generically titled cam belt chnge, one for the 999 I believe and another for a dual spark engine.
I only ask because I haven't found a c belt change guide specific to my '93. I don't have a Hayne's manual right now & a '91 workshop manual that doesn't cover the belt changes some reason. I think there may be a workshop manual for my year online that I have already been pointed to and will check tonight.
I reshimmed the transmission drive shaft. I had .45mm of end play, about .35 too much, now I am at .05 and reassembling the engine.
https://www.youtube.com/watch?v=9vzPZ84ZRjU
If this is the video you are talking about, then yes, it is for the '93 900. Just make sure all 3 marks on the cam belt pulleys line up with the marks on the covers or crankcase, and use the 5 and 6mm allen wrench tension adjustment method, and it will all go well. Not too hard really.
Average Weird Guy.
Well c/f parts are kind of a subjective thing HYPERR,everyone has their own opinion as to what exactly constitutes quality.
I can tell you that the gauge panel I have has a smooth glossy finish,there are no bubbles or pits in the resin,the carbon weave is evenly spaced and symmetrical and the slanted pattern of the weave is very pleasing to the eye,the panel itself is fairly thick and sturdy and has been CNC machined so the edges are square and precise,and as you can see in my pic the panel lines up perfectly with the dash lights and gauge mounts as though it was always meant to be there.
You really couldn't ask for more,so I guess I'd have to say that the overall quality is pretty darned good considering the price that I paid for it.
For what it's worth HYPERR,I've purchased quite a few name brand c/f parts for my bikes over the years that I paid a whole lot more for and sometimes came away disappointed because the quality,fit,and finish on a select few of those pieces wasn't even anywhere near as nice as it is on this cheaply priced Skur gauge panel.
