1541 - 1560 of 1587 Posts
2007 GT1000
Scrubbed the battery box and got the battery off the charger. I’ll install it tomorrow and bring it back home from remote storage so I can wire it for my heated gear.
Installed a new pressure plate and clutch cover today.
Can I just check something. Is it normal for the clutch to rattle/chatter at low revs. It does it when the clutch is disengaged, but seems to do it intermittently when I roll off the throttle too?
Are you sure the pressure plate was aligned properly with the drum? The springs and retainers seem a but crooked. If the noise you mentioned is new, the plate is probably not seating correctly.
Pretty sure it is. I've ordered silver spring collars anyway so I'll double check it's flush when I put them on
.......today I finally did find the 5 minutes I needed to change the stock seat to a NCR Alcantara seat.
Maaaaan, I am getting lazy...... :unsure:
1003887
1003888
.....next job is belt change. The bike has now done 3800 km ( 2360 miles ) since the first and only belt change.
Ciaooooooo
Moller
Ciaooooooo
Moller
I’m considering getting this seat for my biposto. Do you find it more comfortable than stock? How long did it take to get it? Where’d you get it from? How much?
Oh wow. I didn’t know they came in black. Added that to my wish list
JC Pak Bikes sells NCR seats. I think you can also buy NCR stuff from the oem
2007 GT1000
I rode mine today. About 40 miles round trip to go see a customer. Low 50s and was slightly chilly. I did surface streets only so did not freeze solid. I need to wire up my heated gear.
Hello Mike :)
I am a little embarrassed to tell you that I have not yet tested the seat.
As I wrote I have just mounted the seat. It has been laying around for a while after I treated with Carbon Collective Repel Fabric Protectant - and the weather here in Denmark are just soooo cold and wet.
I purchased the seat from Carbon4us in Spain.
I got the seat 4 or 5 days after I did place the order. Yes I was chocked too, but they must have had the seat in stock.
The black Alcantara seat has Reference #: NCR.80.00.004 and the tan Alcantara seat has Reference #: NCR.80.00.001.
The black Alcantara seat for their Mike Hailwood TT Replica bike.
The black and tan solo seat is 662,17 € and the tan biposto seat is 722,01 €.
The black biposto seat is not in the NCR catalog but I have seen it on images on the net - so it can be ordered.
Ciaoooo
Moller
Official Retired Person
Discussion Starter #1,551
Dropped it!
See the Tag Game thread.
Discussion Starter #1,555
Fixed the rear brake pedal that I bent the other day. This is the second time I've straightened this pedal. Both times parking lot tip overs. Oh well, twice down in 14 years isn't bad at all.
Before -
And after -
.....today I did prepare for the belt change on my Paus Smart.
I do like when I know I have all the tools and parts before a job. Less stress
Ciaooooo
Moller
.....just did the belt change.
Before I did remove the old belts I did measure the tension.
They had dropped to 84 Hz from 110 Hz over a period of 3800km (2375 mi) and 1 year and 11 months.
Ducati says they are allowed to drop to 90Hz, but I have not bothered to check the tension.....
The old belts looked like new but I did change them anyway.....
Now new belts have been installed and they were dialed in to about 110Hz.
After 40 minutes the job was done.
Next up is oil change
Have a nice day - ciaooooo
Moller
Hi guys - long time no see.
Over the next few months I am going to try to put this poor beast back on the road. I haven't even cleaned the dirt off of it from the last track day crash in 2019. But now my daughter is going to start riding (CBR250R) and she needs Dad for a riding buddy. Getting this old girl road-worthy again should be cheaper than buying something else to use. Plus, I don't have room for any more old bikes.
"Cheaper" now....but I have been eyeing those twin can Zard full systems on ebay...(my Arrows is slightly crumpled), and if I want to keep my 4-pot track calipers I can't go back to stock wheels....and the 3-spoke Brembos on it now are pretty frumpy...wonder what a set from a 999 go for nowadays....
Oh shit....
1004673
Changed timing belts, spark plugs, did oil change and brake/ clutch fluid change on the GT1000 today. First belt change for me. No one got hurt, no fires or locusts so I think I'm good to go. Looking forward to the beer from @ncgt1000 too ! 😃
Good for you and ebsilon on changing your belts. I just took my Paul Smart into the DucShop last week and had them do the 7500k valve check and belt change. For my first service on both the PS and the 1000s, I wanted to have someone perform the valve job and make sure the guides were in good condition and not loose. Tech said all of my valves were on spec, I am at 6998 miles and this was the first check for the valves.
