I have been working on my 900 since the day I bought it in April of 98.
So far:
BST wheels, Braketech ductile iron Axis rotors, Brembo billet GP calipers
Ohlins R/T forks, Penske shock carbon front fender, Cycle cat triple clamp Speedhut speedo, dumped stock gauges and speedo drive, Brembo radial clutch and brake master cylinders, Woodcraft clip-ons and rearsets
Ben Fox lightened polished crank, Carillo rods JE pistons, MBP ported heads with OS valves
Split Kehein FCR 41mm carbs with pod air filters, dumped the battery carrier and air box
Aluminum slipper clutch, lightened clutch case and aluminum clutch cover
2-1-2 underseat SS exhaust from Doug Cook
Fiberglass seat and fairing with aluminum Motoholder fairing bracket
Shorai battery with cut down race wiring harness, just the bare minimum for ignition, starting and charging
