I'm doing my first valve job on my 04 999 and i'm pretty sure i've made a mistake somewhere. All of the opener clearances are .004mm or less. some are <0.002. closers range from .003 to .007.
my understanding is that opener clearance should increase with time, not disappear. below is a pic showing the cam position. i'm pretty sure this is TDC on the compression stroke. valves are clearly closed when i rotate the engine a bit either direction.
any ideas?
thanks
chris
any ideas?
thanks
chris
