998 and all testastretta are not known to be hit by flacking rockers.
Have they been already checked?
I agree. Also, the pieces sound too large for rocker flakes. Sounds more like gear or bearing race issuesEl_Gladiator said:998 and all testastretta are not known to be hit by flacking rockers.
+2El_Gladiator said:998 and all testastretta are not known to be hit by flacking rockers.
Ride it!Buckelew said:If the flywheel nut has loosened up, you could see it by looking in the inspection port on the left side - but not a problem with the 998's. There have been a couple of cases of testastretta rockers flaking - but not many.
For the first few oil changes, you'll find all kinds of crap floating about in the motor and lodging in the screen or depositing themselves on the drain plug. "manufacturing swarf" is the technical term for this detritus. metal bits leftover from machining and not cleaned out, excess gasket sealant that breaks off, thin metal sections from the castings that break off.....lots of stuff.
I'd change the oil and not worry about it, then take it in for the service. just keep an eye out at oil changes.
level7 said:Wow, i'm pleasantly surprised by the responses on the post. Since it is a low mileage bike, I don't know how may oil changes were done before mine. Maybe could be the 1st or 2nd after the 600 mile change.
I did find perma-gasket material in the screen as well.
Thanks all.
amullo said:Don´t worry about it. Since it has such a low mileage, I´d agree with Buckelew. Just ride it. The engine isn´t broken in yet and your still going to get metal shavings from the breaking in and left over material from the forge.
//amullo
+2 on this [or is that +3 or +4!]Buckelew said:If the flywheel nut has loosened up, you could see it by looking in the inspection port on the left side - but not a problem with the 998's. There have been a couple of cases of testastretta rockers flaking - but not many.
jets don't have oil galley plugs that back out of their crankshafts. during this down time, between race seasons, I'd suggest pulling the vertical cylinder and rotating the crank so that the journal is up high. Then look off to the left side of the crank journal and see if there's an aluminum plug backing out and machining itself against the outer race of the crank bearing.Maine748 said:My 1990 750 race bike has metal in the oil every time. A jet mechanic told me that if the metal pieces aren't big enough to have a part # on them, don't worry.
